Old 12-10-2011, 02:16 AM   #1
Basement BTU's
I have a one bedroom apt. in the basement. The bedroom is 500 sq ft., the living room/kitchen area is 450 sq ft. My a/c installer just put in a Mitsubishi split ductless system, which has two air handlers and a condenser outside. Each unit is 9,000 btu's. My ceiling is 7ft 8in. and there's no direct sunlight. Is that enough? (Because my research keeps telling me I need 15,000 btu's in the bedroom and 13,500 btu's in the living room/kitchen area).
Please advise! Thanks
jgb0928 is offline   Reply With Quote
Old 12-10-2011, 06:58 AM   #2
Basement BTU's
That should be more then enough. Basements have very little cooling and heating loads.
Old 12-10-2011, 07:01 AM   #3
An old Tradesmen
Basement BTU's
Probably have a lot more capacity then you need. Doesn't take much to heat or cool a below grade basement.
Old 12-10-2011, 07:26 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Basement BTU's
500 sq ft bedroom?
plummen is offline   Reply With Quote
Old 12-10-2011, 07:34 PM   #5
REP
Basement BTU's
The OLD rule of thumb which was always too big was 1 ton per 1000 sq feet.
You have a ton and a half for 1000 sq feet.That plus in a normal basement the earth is insulating at least 3/4 of your walls.That means you have a much lower need than a stucture all above ground.Just be glad that each indoor unit has a thermostat or else it would freeze you out.
REP is offline   Reply With Quote
Old 12-10-2011, 09:28 PM   #6
Basement BTU's
Originally Posted by plummen View Post
500 sq ft bedroom?
Yes... I wanted to make a separate storage area, but the building dept won't allow me to put up any walls, so I have to keep it one huge room. (Which is fine).
Old 12-10-2011, 09:30 PM   #7
Basement BTU's
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
Basement Cooling BTU requirements? neilt HVAC 5 05-29-2010 04:26 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
