Old 06-05-2009, 08:57 AM   #1
Basement bathroom exhaust fan
Hello,
Is the bathroom exhaust is required by code in the basement. I put the fan, and it vents into the utility room. Inspector told me to tie it to a vent going outside. I have power vented water heater and I am afraid to tie into that because of backflow concerns.
How and where can I tie this exhaust into
-Shaw
sjahan22 is offline   Reply With Quote
Old 06-05-2009, 03:41 PM   #2
Xtreme DIY'r
What are you trying to exhaust?
Moisture (shower or bath) or just a toilet - smell?
How far to an outside wall?
Old 06-05-2009, 05:29 PM   #3
Moisture and smell. It has both shower and toilet. The fan is closer to the toilet side.
Old 06-05-2009, 05:43 PM   #4
DIY'r
ScottR's Avatar
There's an excellent chance that would be prohibited by code, and a bad idea for the reason you said.
You might not be able to tie it in anywhere; best bet would be to extend the duct and go out a wall, or through the rim joist if your basement is full depth. (And if code allows you to do that.. you can probably ask the inspector for a recommendation).
ScottR is offline   Reply With Quote
Old 06-08-2009, 10:34 AM   #5
Would I be able to tie this into the plumbing vent. I have vent from my sink (in the basement going up and out)
Old 06-09-2009, 10:32 AM   #6
30 year tech
hvac122's Avatar
No. You need to run it outside by itself. The only other thing you could tie into would be another exaust fan but then you would need to increase the size of that to the outside.
hvac122 is online now   Reply With Quote
Tags
bathroom fan exhaust
Basement bathroom rough in efrobert Plumbing 2 06-23-2011 05:54 PM
Basement Bathroom - Sheetrock - Moisture Issues. mikeynpz Building & Construction 2 05-24-2009 11:08 AM
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 01:17 AM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 11:10 AM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-23-2006 12:03 AM
