-   -   Baseboard versus heat pump (http://www.diychatroom.com/f17/baseboard-versus-heat-pump-26625/)
kfowle3 09-10-2008 05:17 PM
I know baseboard heaters are supposed to be more efficient than heat pumps, but with today's oil prices (mine is oil to hot water heated) I wonder if a fuel pump isn't more efficient. My baseboard isn't working right now, and I'd have to put some serious money into getting it fixed, so should I just get a fuel pump set up with my existing AC? Any advice would be great.
Thanks!
handy man88 09-10-2008 10:15 PM
Thanks!
Depends on where you live.
If you live up north where the winters are cold, that heat pump will not work efficiently. It'll cut over to resistance "emergency" heating, and that will be costly.
kbsparky 09-10-2008 10:26 PM
Are your baseboard heaters the hydronic type?
A high-efficiency heat pump may have energy savings over the high price of oil or gas these days.
You should do an analysis of the cost per BTU of heating with gas, oil, and electric. The answers may surprise you. :eek:
dac122 09-11-2008 08:39 AM
I'm not sure how you're using the term efficient here, but many people, including myself, do use heat pumps up north to effectively lower their heating bill. Mine was on this morning and I can bet it was cheaper BTU cost to run than my 92% AFUE Propane forced air.
If you live in a climate where a heat pump cannot provide all your seasonal heating needs, you're gonna need a secondary heat source. So you either need to fix that boiler or replace it with something else.
Without knowing where you are located it is impossible to even guess.
handy man88 09-11-2008 02:25 PM
I'd go with the boiler.
The heat from a boiler or gas furnance just feels much warmer than from a heat pump blowing cold air or uneven heat from a resistance heater.
sgthvac 09-11-2008 11:45 PM
Heat pumps are more effiecient than gas furnace unless your electric rate is high such as in California. The effiency ratio is about 3:1. I will tell you though, if your wife or significant other is always cold save yourself the trouble and repair the boiler. Nothing produces a more even and comfortable heat than a hydronic system.
kfowle3 09-12-2008 12:44 AM
location
I am located on the eastern shore of Maryland, so it;s not real cold here.
kfowle3 09-12-2008 12:48 AM
Baseboard heaters
In response to "Are your baseboard heaters the hydronic type":
I'm not sure, but I know the oil heats up water that runs through them (sorry if that doesn't help). I'm trying to understand and learn more about how my system works.
kfowle3 09-12-2008 12:50 AM
Replies
How do you reply to an individual comment (so that text shows in the same box)? And to sgthvac's comment, I am the wife :)
kbsparky 09-12-2008 03:15 AM
Where? I'm near Salisbury ... :thumbup:
Are you on DP&L or Choptank?
Maybe we can get a quantity discount, as I am looking to install a new high-efficiency heat pump as well.
So far, I have asked 3 fellow contractors for prices, and not one of them has responded. You can't tell me that they are slow on work!! :furious:
kbsparky 09-12-2008 03:17 AM
You hit the "quote" box in the bottom right corner of the message you want to quote. Then type in your reply in the dialog box. :thumbsup:
dac122 09-12-2008 08:40 AM
Then I believe in that region you could go with a heat pump and backup heat strip. The heat strip would be needed rarely.
Having said that, if you choose a heat pump you will need duct work run to all heat zones as I have never heard of a hybrid heat pump setup that mates to boiler. If one did, I'd wonder about its efficiency.
What kind of serious money are you looking at to repair your current system?
dac122 09-12-2008 08:59 AM
I'm not sure I agree here. If by more efficient you mean from a purely theoretically standpoint a heat pump is a heat transfer engine, and even at low outdoor temps can have a Coefficient of Performance above 1, then yes I would agree. If by more efficient you mean from an economic standpoint I must disagree.
And since I believe the original thrust of the OP's question was asking an economic question, I would advise the OP to consider these factors when comparing two heating systems: efficiency of your furnace/boiler, cost of your fossil fuel, cost of your electric, HSPF and COP curves of the Heat Pump, heat loss of the structure, and initial cost of install or repair.
sgthvac 09-12-2008 09:23 AM
Thank you, I never knew what the quote box was for.
Now about your system, yes, you have an oil fired boiler and it sounds like you have central air as well, if I read an earlier post correctly, you already have the duct work in place. With that in mind, I think going to a heat pump with electric heat strips would work well for you. Heat pumps are definately more effiecient. That being said, you have to understand that instead of getting 180 temp. coming off the baseboards the temp will be 90-110. a vast difference in comfort. I've seen some people have a heat pump installed and have it remove because they could never get used to the home feeling drafty when they are sitting down in the evening. Pesronally, I have a 96% eff. natural gas boiler that also heats my domestic hot water as well and I love it unfortunatly eff. for oil boilers have not increased above 75-80%.
kfowle3 09-12-2008 11:32 AM
Testing, testing :laughing:
