Baseboard Thermostat Failed? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-20-2011, 10:40 PM   #1
Have a wall-mounted 240v thermostat that serves 2 baseboards in the same room. Since the room is seldom used, the thermostat is in the 'off' position. The other day I was in the room and it was like a sauna. Baseboards were hot, as was the thermostat itself. Turned the breaker off and in a couple of hours the room cooled down.
This evening I turned the breaker on, with the themrostat still in the 'off' position, and in 30 minutes or so the room was warming.
Is it possible that I have a thermostat that has failed? If so, what is the recommended test procedure? The thermostat in question is an Intertherm Model 7-D. I believe this is a 4-wire stat.
Back40Help is offline   Reply With Quote
Old 01-21-2011, 05:08 AM   #2
An old Tradesmen
Rewards Points: 6,456
With breaker off. Remove stat from wall, look to see if any bare wires are touching. If not, and its turned off but still heating the room when power is on. Its a bad stat.
Baseboard Heater Thermostat Ground Wire ? sciron Electrical 6 02-19-2011 06:28 PM
Newbie question - thermostat functioning and baseboard heaters keith-k HVAC 2 10-26-2010 10:20 AM
One thermostat for two baseboard heaters wired this way GabrielB Electrical 4 12-23-2009 08:40 PM
how to wire a low voltage thermostat to a baseboard heater db3iii HVAC 4 06-05-2009 09:03 PM
Help move baseboard heater thermostat and avoid electrocution Gunserotti Electrical 28 01-04-2009 05:48 PM
