Baseboard Temp - HVAC - DIY Chatroom Home Improvement Forum
Old 11-11-2008, 08:37 AM   #1
Rewards Points: 37
baseboard temp
My Photos
basebaord temp?
Is there a rule of thumb for the actual temp of my baseboard heaters?
The boiler shuts down at 190 degrees and using an infrared thermo I checked the outlet pipe and it is close to 190. The inlet side is between 160 and 175 degrees, depending on which zone is on. I guess this depends on the length of the zone. The base board heaters are between 75 and 90 degrees.
nbmech is offline   Reply With Quote
Old 11-11-2008, 11:52 AM   #2
Originally Posted by nbmech View Post
My Photos
basebaord temp?
I keep mine at 180(the lowest it will go) when it's mild outside, and turn it up to 190-200 when it get very cold(<20F) out. I also installed a Beckett Heatmanager which adjusts the burn cycles according to the rate of heat transfer.
jerryh3 is offline   Reply With Quote
Old 11-11-2008, 12:43 PM   #3
Rewards Points: 37
what does the Beckett Heatmanager do?
Old 11-11-2008, 02:48 PM   #4
http://www.becketthm.com/
Old 11-11-2008, 04:50 PM   #5
have you bled the system sounds like air unless its just miles away from the boiler
kennzz05 is offline   Reply With Quote
Painting baseboard tips/tricks mahjohn Interior Decorating 15 10-29-2011 11:54 AM
Tile baseboard with carpet? bpak04 Flooring 2 11-03-2008 12:28 PM
Replaceing Baseboard to curvy wall problem agfrag Carpentry 13 08-29-2008 03:40 PM
convert from gas boiler to electric baseboard marks5894 HVAC 1 10-21-2007 12:22 PM
Baseboard Question in New Home BusterPercheron Building & Construction 5 11-20-2006 06:16 AM
