-   -   baseboard temp (http://www.diychatroom.com/f17/baseboard-temp-31630/)
nbmech 11-11-2008 08:37 AM
baseboard temp
http://www.diychatroom.com/images/buttons/add_album.png My Photos
http://www.diychatroom.com/images/icons/icon1.gif basebaord temp?
Is there a rule of thumb for the actual temp of my baseboard heaters?
The boiler shuts down at 190 degrees and using an infrared thermo I checked the outlet pipe and it is close to 190. The inlet side is between 160 and 175 degrees, depending on which zone is on. I guess this depends on the length of the zone. The base board heaters are between 75 and 90 degrees.
jerryh3 11-11-2008 11:52 AM
I keep mine at 180(the lowest it will go) when it's mild outside, and turn it up to 190-200 when it get very cold(<20F) out. I also installed a Beckett Heatmanager which adjusts the burn cycles according to the rate of heat transfer.
nbmech 11-11-2008 12:43 PM
what does the Beckett Heatmanager do?
jerryh3 11-11-2008 02:48 PM
http://www.becketthm.com/
kennzz05 11-11-2008 04:50 PM
have you bled the system sounds like air unless its just miles away from the boiler
