Old 04-23-2006, 11:31 PM   #1
Question
Baseboard Hot Water radiators
Can someone tell me how efficent this type of heating is? Also, wondering can someone give me a rough estimate on how much it would cost to have new baseboard hot water radiators installed in a 1400 sq ft house? They need to be replaced as the metal coils (?) are bent and very old. We were told that new ones would be throw out alot more heat.
Would a plumber or a HVAC person do the job?
hotdiggitydog is offline   Reply With Quote
Old 04-24-2006, 10:30 PM   #2
coolmen's Avatar
more of a plumber/heating trade
coolmen is offline   Reply With Quote
Old 04-25-2006, 12:27 AM   #3
I don't buy that. Add some baseboards to throw out more heat but leave the old ones alone unless they are too beat up to look at. If you take the old ones out I'll buy them from you and use them in a rental. There is nothing wrong with them. HS.
Copper pipe with aluminum fins. Pretty simple. The copper last forever and the fins just get yucked up with stuff and bent but you can't hurt them. I own two hot water systems and i don't think they can compare to forced air for cost but I like the heat better.
K2eoj is offline   Reply With Quote
Hot Water Baseboard Heat danthemandan HVAC 1 03-19-2007 10:27 AM
Air in hot water baseboard - help! heydobbs HVAC 6 12-08-2006 06:08 PM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 02:11 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
