Baseboard Heating Pipes Wrap The Entire Room - HVAC - DIY Chatroom Home Improvement Forum
Old 07-14-2011, 12:26 PM   #1
Baseboard heating pipes wrap the entire room
I've got baseboard heating pipes that wraps around the entire room. The room was gutted and proper insulation was installed (there was very little there). So now I'm wondering can I just run the baseboard pipe down one exterior wall and wrap it back on top of the first run. The first run down would have the fins and the run back would just be plain pipe. Does creating a 180 degree turn back on the piping cause a pressure flow issue?
iamsnowman is offline   Reply With Quote
Old 07-14-2011, 12:29 PM   #2
i did that numerous times over the years in western ny. was the only way to do it when you couldnt get access everywhere. as long as you still have enough feet of fins to heat the room it shouldnt be a problem.
Old 07-14-2011, 04:28 PM   #3
Rewards Points: 1,216
Should be fine.
COLDIRON is offline   Reply With Quote
Old 07-14-2011, 06:11 PM   #4
An old Tradesmen
Rewards Points: 7,408
Might want to do a load calc and see if that will be enough heat for that room first.
Old 07-15-2011, 02:24 PM   #5
Thanks for the many replys; this is great. I'll look for a load calc; just to make sure.
Need to bleed a hot water baseboard heating system Brewmaster HVAC 4 02-17-2011 07:04 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 09:03 PM
removing some baseboard heating Susque Plumbing 6 12-06-2008 07:04 PM
Heating issues in 1 upstairs room Baserunner HVAC 6 12-30-2007 08:14 AM
How many heating vents needed per room? AllGoNoShow HVAC 4 01-23-2007 04:06 PM
