Old 03-31-2007, 03:33 PM   #1
baseboard electric heaters?
Im currently remodeling a house and some of the baseboard heaters are out dated. I need to know how much and what size per room. i think theres a formula for this but im not sure. I live in the north east so i get a lot of cold and snow. and ill be insulating as i go. any help would be greatly appreciated......Rick.......
rick32 is offline   Reply With Quote
Old 04-01-2007, 10:50 AM   #2
scotch on the rocks
hvactech's Avatar
You must figure out the voltage of the heaters (most likely 220V) and multiply it by the amperage draw and the result will be the wattage, for example at 220V and 20 amps the heater would be rated at 4400 Watts, then divide 4400 by 3.414 BTU’S per watts to get the heater BTU rating of 1288.
Most of the time you may find the watts ratings stamped somewhere in the heater, also to find the amp draw you must find the resistance of the heater using an ohm meter and divide the number by the heaters voltage for example a 220 volt heater with a resistance of 5 ohms will draw 44 amps.
Again most of the time you don’t need to use all those calculations because the number are stamped somewhere in the heater. Good luck.
check this link for more tech info http://www.tombling.com/heaters/heatloss.htm
hvactech is offline   Reply With Quote
Tankless Water Heaters Recalled for Repair Due to Carbon Monoxide shimp Plumbing 1 01-22-2008 07:52 PM
Removing Baseboard Electric Heaters gieriscm Electrical 12 11-12-2007 05:59 PM
Why do baseboard heaters have 2 circuit breakers? mhaucke Electrical 4 07-08-2007 06:10 PM
Need help with finding very wide baseboard Showbiz Carpentry 2 05-28-2007 08:52 AM
Electric tankless water heaters; any experiences? moneymgmt Plumbing 14 05-15-2007 11:36 AM
