Base Board Heating System - HVAC - DIY Chatroom Home Improvement Forum
Old 11-28-2010, 03:34 PM   #1
base board heating system
I replaced the pressure reducing valves on my boiler but it wont adjust. I turned the adjutmtent screw on top clockwise and counter clockwise and nothing happened. I also ensured that it was installed in the proper directions. Any suggestions
sanchezc is offline   Reply With Quote
Old 11-28-2010, 04:23 PM   #2
An old Tradesmen
Rewards Points: 7,350
May have a clog in the pipe feeding it.
Old 11-28-2010, 04:39 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,... Or the pipe after it....
It shouldn't need adjustin' anyways, they come preset at 12psi...
Old 11-28-2010, 06:25 PM   #4
Do you have a backflow preventer on this system...If so then you will not be able to adjust easily as the check valve wont allow pressure to back bleed. Are you trying to increase pressure or decrease it. I agree with the others as well could be an obstruction in the supply line.
Work4living is offline   Reply With Quote
Open Hydronic Heating System... how / need to bleed? MtnMan7 HVAC 1 11-19-2010 03:51 PM
New Heating & AC system takes long time to warm up home poston8 HVAC 10 11-10-2010 03:26 PM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 05:23 PM
Air Scoop direction on a hot water heating system mmcr179 HVAC 2 03-17-2010 06:20 AM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 10:03 AM
