Barometric Dampers On Oil Furnace? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-19-2009, 10:56 AM   #1
Rewards Points: 107
Barometric Dampers on oil furnace?
Are these needed on the newer furnaces? I have a Lenox furnace that is about ten years old. 80% efficiency if I recall correctly. Thanks
thunderhead is offline   Reply With Quote
Old 09-19-2009, 11:24 AM   #2
An old Tradesmen
Rewards Points: 7,830
Yes they are.
Without it. Your combustion efficiency will wavier, flame control will wavier, and you could end up having a chimney fire.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 07:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
