Barometric Damper - HVAC - DIY Chatroom Home Improvement Forum
Old 01-10-2011, 07:29 PM   #1
Barometric Damper
I had a new oil burning furnace installed last year. It's a Carrier 3 burner unit - don't know the model. The flue is 5" round and exits the top, and there is a barometric damper in the pipe just before it goes into the masonry chimney. The chimney is about 30' high.
I notice a slight oder of oil exhaust when the furnace runs. I also noticed today the BD does not have the screw with weight attached to the flap. Is this ever proper - or should they always have the weight? There is also a little soot on the outside of the damper flap.
Should I go get the weight, and if so, is there an adjustment procedure?
Thanks for any help.
'Frank
OffRoadAudio is offline   Reply With Quote
Old 01-10-2011, 08:01 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 396
Post a pic of it. Most of the ones I have seen have a weight and NO you cannot just set it yourself. Needs to be set with a draft gauge for proper overfire draft etc.
Old 01-11-2011, 04:21 AM   #3
An old Tradesmen
Rewards Points: 8,228
Sounds like it isn't burning right either. needs to have weigh installed/reinstalled, and then set up properly, after a good cleaning.
barometric damper paul1969f HVAC 15 01-24-2013 09:51 AM
Zone Damper Questions rkelly_83543 HVAC 3 04-18-2010 03:52 PM
Zoning question spyder24 HVAC 23 04-03-2010 07:12 PM
Damper door on Furnace not opening all the way tro222 HVAC 11 02-08-2010 08:28 PM
Installing Flue Liner thru Damper MikeinBurien Building & Construction 0 10-16-2009 11:39 PM
