Old 10-05-2012, 01:52 AM   #1
bare thermostat wire = bad?
First of all, Im new to the forum. Hello everyone.
My wife and I just purchased a home (built in '78) and are slowly moving in. I was attempting to swap out the basic thermostat that came with the house tonight (newer, just no programmability). Once I got the box off, I noticed the coating of one of the wires (green coated wire plugged into G port), was split, and the bare wire was exposed. the wire appears to be split up into the harness, so im not sure I can repair it without ripping out drywall.
my questions are:
does it matter that this wire is bare (is it a safety hazard)?
if yes, what is the best way to repair this problem?
thanks for any suggestions
HItransplant is offline   Reply With Quote
Old 10-05-2012, 02:13 AM   #2
DIY Enthusiast
sublime2's Avatar
The wires to the thermostat are low voltage.
No real safety hazard.
Just be sure that the green ( fan relay - turns blowers on) wire dose not come into contact with any metal.
sublime2 is offline   Reply With Quote
Old 10-05-2012, 09:21 AM   #3
put a little elecrical tape around it ..its only low vaoltage...may be easier that tering wall apart
carmon is offline   Reply With Quote
Old 10-05-2012, 10:37 AM   #4
Missouri Bound's Avatar
As long as it's the only wire that is bare in the cable it will be ok. You don't want it touching adjacent wires, any metal or other parts of the thermostat. If it's loose enough and the wire is direct to the furnace you may be able to pull it out and pull the new wire in place.
Do you want it your way or the right way?
Old 10-05-2012, 01:38 PM   #5
I gave the bundle a tug and it seems pretty secure.. not sure I could pull it through, but Id rather this option than taping. As your sig denotes, Id like to do it right.
Low volt can still start a fire, right?
thanks for all the help everyone.
Old 10-05-2012, 01:55 PM   #6
DIY Enthusiast
sublime2's Avatar
No. The likelihood of that happening are slim to none.
If concerned,wrap it with electrical tape as suggested.
Replace 3 wire electric baseboard thermostat Bhurl5 HVAC 4 11-27-2011 09:07 PM
Hooking up new thermostat. Just need some clarification cruzmisl HVAC 34 11-04-2011 07:05 PM
Baseboard Heater Thermostat Ground Wire ? sciron Electrical 6 02-19-2011 06:28 PM
4 wire thermostat to 2 wire Tammpatt Electrical 1 01-10-2011 02:46 PM
Replacing a two wire heat thermostat to a four wire cibao67 Electrical 2 03-01-2010 09:42 AM
