Banging Noise - HVAC - DIY Chatroom Home Improvement Forum
Old 02-18-2012, 06:15 AM   #1
banging noise
we had replaced our gas furnace about a year ago. It is a weil Mcclain brand. we had some banging noise before, however, after replacement the banging noise is worse. We hear it in different places every time when the heat goes on. We had professional looked at it and they kept tilting the heating units higher stating that it was the flow of water making the noise. Still not working-the banging noise is getting worse. HELP!
jacandy is offline   Reply With Quote
Old 02-18-2012, 07:06 AM   #2
Experienced
Jackofall1's Avatar
Hello and welcom jacandy, to the best darn DIY'r site on the web.
Is the system a steam or hot water system?
Mark
Old 02-18-2012, 07:40 AM   #3
sounds like water hammer to me.
you are getting hot fluid (steam or liquid water) that is contacting a cold spot in your pipe system.
There are guys here other than me and Jackofall1
who can answer your questions more knowledgeably. Please wait for their responses to your question.
hvac5646 is offline   Reply With Quote
Old 02-18-2012, 07:58 AM   #4
thanks for your reply! we have a hot water system. can the water hammer be fix or should i contact another pro?
Old 02-18-2012, 08:07 AM   #5
I would wait and see what a boiler man has to say from this board..
Old 02-18-2012, 08:17 AM   #6
Experienced
Jackofall1's Avatar
When does the banging sound occur?
When the pump starts or shuts down?
Is the banging sound continuous throughout the heating cycle?
What is the operating set point of the boiler?
How many zones in the system?
Mark
Old 02-18-2012, 08:30 AM   #7
the banging starts when the heat comes on, in the pipes then some hissing noise occurs. It is not continuous. Not sure what you mean by the operating set of the boiler. It was set by the boiler/plummer. He had stopped by several times to fix the problem which has not resolved. Want to get another opinion and have an idea how to fix it.
Thanks again
Old 02-18-2012, 08:51 AM   #8
Experienced
Jackofall1's Avatar
The operating set point of the boiler is the temperature the boiler is trying raise the water to.
Sounds to me that you have too much air in the system and it needs to be bled out.
Mark
Old 02-18-2012, 08:53 AM   #9
you could have airs trapped in the lines too...the hissing could be an eliminator expelling air or it could be a pressure relief opening.
Do you know what water temperature the boiler is set to maintain?
As far as fixing it I would need to know a bit more about the install.
The piping if not conducive to the new boiler could be causing part of the problem. Would have to see a pic of piping loop (lay out) before that determination is made.
Pics of the boiler would help a lot.
Can you tell me some of the things that your plumber told when he came back to look at the noise problem.
Old 02-18-2012, 08:57 AM   #10
Assuming air is the problem, the system is not bleeding it off as it accumulates.
There are devices that can be added to improve the elimination of air. Do you see on your invoice or were you told that the plumber was going to do this?
Old 02-18-2012, 12:25 PM   #11
how
Rewards Points: 1,104
The most common boiler banging sounds that come from different locations are heating pipes that are binding and releasing as they expand.
Where those pipes were formally able to slide back and forth on their hangers during that lateral expansion, they are now sticking and then letting go with a banging sound..
Air in the pipes will only result in the sound of running water or if it get so bad that it restricts the water flow, a hammering sound from the boiler itself. The hissing sound can usually be traced to the air bleed valve outlets or the pressure relief valve. Tap the two halves of the expansion tank beside the boiler to make sure that the one half sounds empty and the other- full of water. If both halves sound the same, then the expansion tank is shot. If your expansion tank is in the ceiling then it may just need to be set up again.
Reading us the tridicator readings for psi and temp during the boiler run will tell us a more complete picture.
how is offline   Reply With Quote
The Following 2 Users Say Thank You to how For This Useful Post:
ben's plumbing (02-18-2012), hvac5646 (02-18-2012)
Old 02-18-2012, 03:40 PM   #12
Experienced
Jackofall1's Avatar
Air trapped in a boiler will cause banging and or system pressure is too low allowing steam to form in the furthest radiators.
Bleed air from boiler and or increase system pressure to a range of 12-15 PSI.
Old 02-18-2012, 04:10 PM   #13
An old Tradesmen
Rewards Points: 7,776
Please post pics of the boiler. And if you can look at the aquastat and post what temp it is set to, they will be helpful also.
Do you know if the new boiler is sized to the house heat loss, or the size of the radiators.
old wall furnace makes banging noise KarlJay HVAC 22 09-08-2011 01:55 AM
maytag washer makes banging noise atechdrew Appliances 1 04-25-2011 08:38 PM
Steam pipes generating banging noise Dezso3 Plumbing 7 02-20-2010 05:31 PM
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 01:17 PM
Hear a Banging Noise from Bathroom Fan When its Windy wjk7320 Building & Construction 13 09-12-2007 10:13 PM
