Balancing - HVAC - DIY Chatroom Home Improvement Forum
Old 03-13-2008, 01:13 PM   #1
master plumber
balancing
iam a plumber not an ac guy. i installed a ac/heat unit in my attic, the ducting also.what is the best register to use ,that i can balance ,and direct the flow of air. with out hearing that hissing noise.
frodo601 is offline   Reply With Quote
Old 03-18-2008, 04:44 AM   #2
coolmen's Avatar
you would want a wide spacing to cut down on the volocity. check out hart and cooley register A618 or something of this type. more pricer but will do the job and you can adjust air throw 2 ways. I would hope you installed manuel dampers at the supplys so to balance the systems air flow.
coolmen is offline   Reply With Quote
Old 03-18-2008, 06:22 PM   #3
master plumber
dampers
yeah i installed dampers where the duck comes off the plenum. be i pain in the ass to get to.the problem i keep running to. is the whistle but i will try the registers you suggested. thanks
Rehau manifold with Wirsbo PEX Mike Warner HVAC 2 01-31-2009 12:50 PM
balancing a refrig. mbwdds02 Appliances 1 04-12-2007 10:49 AM
Pressure Balancing Valve Installation kpstanton Plumbing 2 03-01-2007 10:30 AM
how to make a pressure balancing loop gib7464 Plumbing 1 03-25-2006 08:31 PM
