Balance Valves - Worth It? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-30-2009, 02:14 PM   #1
Joe F's Avatar
Rewards Points: 294
Balance valves - worth it?
I have hydronic baseboard heat with a 4 zone system. Is it worthwhile to install balance valves (I'm looking at Taco valves ~$45 each)? It's my understanding that adjusting them is not a DIY project due to the equipment needed.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 01-30-2009, 02:43 PM   #2
The boiler guys usually come on line at about 4pm.
Hang tight.
hvaclover is offline   Reply With Quote
Old 01-30-2009, 02:58 PM   #3
Joe F's Avatar
Rewards Points: 294
Hang tight.
I was in the Navy for 20 years, I have a soft spot for "boiler guys" Thanks.
Old 01-30-2009, 03:47 PM   #4
Rewards Points: 2,906
Joe:
Basically, a balancing valve is used in single zone heating systems so that each radiator loop offers the same resistance to flow so that you get uniform heat distribution throughout the building. You normally wouldn't use a balancing valve in a radiator loop with a zone valve.
Also, if it wuz me, I would spend a bit more and get better zone valves. I'm sure Taco zone valves work, but they're just plain hard to figure out how to wire them together and to the heating system and such. Take a look at the Honeywell V8043 series of valves; they come with and without end switches and you can buy replacement actuators and motors for them.
I'm not sure if I answered your question. On a zoned heating system, the zone valve opens to provide hot water flow into the radiators in that zone. You wouldn't normally ALSO install balancing valves on the radiator train in that zone.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 01-30-2009, 03:54 PM   #5
Joe F's Avatar
Rewards Points: 294
Thanks Nestor. I think you answered my question. If I understand right, balance valves won't do much for a multi-zone system.
FYI, I know what you mean about wiring zone valves (especially for a DIY'er). My solution was to buy one of Taco's electronic zone controllers. Took out all the guess work.
why do my 1/4 turn valves leak? moondog111 Plumbing 1 12-08-2008 12:09 AM
leaking valves - DIY help wombosi Plumbing 4 11-17-2008 09:32 PM
Hot water radiator parts? Bleed Valves DanBress HVAC 9 11-16-2008 08:23 PM
shut off valves on cast iron radiators bdw2677 Plumbing 2 10-21-2008 08:07 PM
Shut Off Valves Coach Gordon Plumbing 2 04-24-2006 04:13 PM
