Old 03-07-2007, 02:03 PM   #1
Balance??
I am remodeling and need to upgrade my furnace. How do I know if I have enough returns for my supply? And can I have too many Returns?
I also need to run a 50 foot trunk under my crawl for the addition. What size duct should I run? And can I buy this equipment at a Lowe's or Home Depot.
I'm in the Columbus area Ohio.
rodg2915 is offline   Reply With Quote
Old 03-07-2007, 02:27 PM   #2
Balance??
We would have to almost see what you have now, inorder to give you a good answer. Your best bet if you want good results is to pay a HVAC company to consult you........that way if it doesent turn out you have some recourse.
harleyrider is offline   Reply With Quote
Old 03-07-2007, 02:54 PM   #3
Balance??
I can scan and email my drawings if there are any takers.
Old 03-08-2007, 10:59 AM   #4
Balance??
The return size should match the supply size.
redline is offline   Reply With Quote
water leaking from pressure balance spool lauralyn1 Plumbing 16 08-13-2007 05:50 PM
Attic Ventilation - importance of balance FatAugie Roofing 7 08-04-2007 11:57 AM
spring balance in old wood window Kbotard Carpentry 6 05-19-2007 10:32 PM
