Bad Thermocouple In Carrier Furnace??? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-13-2010, 11:33 PM   #1
Post
Bad Thermocouple in Carrier Furnace???
We been having problems with our 20 yrs old Carrier furnace (model# 58GSC065). The furnace has a electric ignition system. After the pilot flame turns on, sometime the heat exchanger burner won't go on, sometime after the heat exchanger burner flames on the blower won't turn on. We suspect it maybe a defective thermocouple issue (not sensing the flame???) but need some expert opinions. Any help will be greatly appreciated. Thanks.
PS We did take out the pilot assyembly and try to clean the thermocouple once before. It got a bit better but then went back to the same problems I described above.
weagle is offline   Reply With Quote
Tags
carrier , furnace repair diy
Need help with thermocouple replacement on MC furnace YerDugliness HVAC 8 01-13-2012 08:24 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 11:36 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
carrier furnace issues sbroways HVAC 2 10-15-2007 09:30 PM
