Old 06-13-2011, 04:43 PM   #1
Bad T-Stat?
If My furnace isn't running and I KNOW I have a bad t-stat could I take the 4 wires off the t-stat and jump out white and green? If the furnace comes on like it's suppose to then that should mean I have a bad t-stat right?
gooch81 is offline   Reply With Quote
Old 06-13-2011, 05:12 PM   #2
biggles's Avatar
Bad T-Stat?
just take the stat off the subbase and jump as your doing R to W should be heat R to G is just fan typical colors standard are red is R and W is white G is green but go with the letters on the subbase and into the furnace controls...yes the stat is faulty if you get those cycles with the jumps pencil eraser on the contacts might help subbase and stat....
T stat with 2 wires on 240? OffRoadAudio Electrical 6 12-13-2011 07:52 PM
Replacement Thermostat Problem! Confuserated HVAC 8 03-26-2010 09:17 AM
LUX digital stat Trane XE80 intermittant problem rossl56 HVAC 6 12-26-2008 06:53 AM
Which Stat for New Carrier 58 MV Chemist1961 HVAC 10 12-21-2008 07:35 PM
ritetemp programmable stat miked18 HVAC 9 12-17-2007 07:20 PM
