Bad Stat ? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-20-2013, 08:47 AM   #1
Rewards Points: 236
bad stat ?
my issue is = the furnace runs per normal, then shuts off. then it starts right back up and runs for 1 min to several mins, it varies , then shuts off. i have new batteries in the stat, no difference. i am figuring that the stat is bad. but could it be something else ? i am getting a new stat today to try out.
Fix'n it is offline   Reply With Quote
Old 04-20-2013, 09:10 AM   #2
An old Tradesmen
Rewards Points: 6,846
Air filter, dirty A/c coil. Blocked registers, or dirty blower wheel.
Old 04-20-2013, 09:15 AM   #3
Rewards Points: 236
i will check the filter, but it was replaced not long ago.
registers are the same.
A-coil was cleaned 1 year ago. and it was NASTY. mostly dog hair. we never had a dog.
the blower wheel does need to be cleaned. but it looked ok last year, and it blows just fine.
this issue just started about 1 month ago.
stat is set to come on at 72, and it goes off at 74. but when it goes right back on, the temp is 73, not 72.
Old 04-20-2013, 09:18 AM   #4
An old Tradesmen
Air current in the wall its mounted on maybe.
Old 04-20-2013, 11:12 AM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 1,774
Yep. remove the stat and stuff the hole in the wall with pink insulation. Check for drafts around the stat like a vent blowing on it or sucking on it/return and modify them if necessary.
Old 04-20-2013, 04:23 PM   #6
AKA HVACTECHFW
Rewards Points: 1,208
When you say it comes back on..... is just the fan coming back on or are the burners coming on as well?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
ben's plumbing (04-20-2013)
Old 04-20-2013, 06:29 PM   #7
Rewards Points: 582
how old is furnace can we see a picture with doors off... i ask because it may have and old fan and limit control which my start the blower for a few moments after a heat cycle...ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
hvactech126 (04-20-2013)
Old 04-21-2013, 07:51 AM   #8
Rewards Points: 236
i thought of that. but nothing has changed all winter. and this just started in the last month.
burners. it fully starts.
i was talking to my wife. she sees the stat a lot. she said it will go to 73. the furnace will shut off while still on 73. then it will start back up and run till the stat reads 74.
Old 04-21-2013, 07:55 AM   #9
An old Tradesmen
You've changed nothing. But a house changes from season to season.
Old 04-21-2013, 08:17 AM   #10
Hvac Pro
yuri's Avatar
probably a bad stat, don't buy a el cheapo. buy a Honeywell Focus Pro from HDepot. the rest is Chineez crap.
Old 05-11-2013, 08:35 AM   #11
Rewards Points: 236
update
i put in a new honeywell stat. the cheaper one, $20 iirc.
so far it seems to be working just fine.
need help upgrading manual merc stat to new digital stat tlb813 HVAC 3 08-13-2012 12:31 PM
T stat with 2 wires on 240? OffRoadAudio Electrical 6 12-13-2011 06:52 PM
Replacement Thermostat Problem! Confuserated HVAC 8 03-26-2010 08:17 AM
LUX digital stat Trane XE80 intermittant problem rossl56 HVAC 6 12-26-2008 05:53 AM
ritetemp programmable stat miked18 HVAC 9 12-17-2007 06:20 PM
