-   -   bad stat ? (http://www.diychatroom.com/f17/bad-stat-177633/)
Fix'n it 04-20-2013 08:47 AM
bad stat ?
my issue is = the furnace runs per normal, then shuts off. then it starts right back up and runs for 1 min to several mins, it varies , then shuts off. i have new batteries in the stat, no difference. i am figuring that the stat is bad. but could it be something else ? i am getting a new stat today to try out.
beenthere 04-20-2013 09:10 AM
Air filter, dirty A/c coil. Blocked registers, or dirty blower wheel.
Fix'n it 04-20-2013 09:15 AM
i will check the filter, but it was replaced not long ago.
registers are the same.
A-coil was cleaned 1 year ago. and it was NASTY. mostly dog hair. we never had a dog.
the blower wheel does need to be cleaned. but it looked ok last year, and it blows just fine.
this issue just started about 1 month ago.
stat is set to come on at 72, and it goes off at 74. but when it goes right back on, the temp is 73, not 72.
beenthere 04-20-2013 09:18 AM
Air current in the wall its mounted on maybe.
yuri 04-20-2013 11:12 AM
Yep. remove the stat and stuff the hole in the wall with pink insulation. Check for drafts around the stat like a vent blowing on it or sucking on it/return and modify them if necessary.
hvactech126 04-20-2013 04:23 PM
When you say it comes back on..... is just the fan coming back on or are the burners coming on as well?
ben's plumbing 04-20-2013 06:29 PM
how old is furnace can we see a picture with doors off... i ask because it may have and old fan and limit control which my start the blower for a few moments after a heat cycle...ben sr
Fix'n it 04-21-2013 07:51 AM
i thought of that. but nothing has changed all winter. and this just started in the last month.
burners. it fully starts.
i was talking to my wife. she sees the stat a lot. she said it will go to 73. the furnace will shut off while still on 73. then it will start back up and run till the stat reads 74.
beenthere 04-21-2013 07:55 AM
You've changed nothing. But a house changes from season to season.
yuri 04-21-2013 08:17 AM
probably a bad stat, don't buy a el cheapo. buy a Honeywell Focus Pro from HDepot. the rest is Chineez crap.
Fix'n it 05-11-2013 08:35 AM
update
i put in a new honeywell stat. the cheaper one, $20 iirc.
so far it seems to be working just fine.
