Is It A Bad Pressure Switch? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-02-2012, 07:26 PM   #1
Is it a bad pressure switch?
When everything is connected I get error code pressure switch on with inducer on. If I disconnect hose that connects pressure switch to combustion chamber it fires right up. If I leave hose off it will work fine. If I connect hose it runs to temp then can't refire. I checked vent pipe and it seems clear. Is it a bad pressure switch, or something else? Is it safe to leave hoses disconnected?
First state is offline   Reply With Quote
Old 11-02-2012, 10:00 PM   #2
how
Rewards Points: 1,070
Check your air & exhaust intake for obstructions. Unfortunately this can also happen with exhaust lines that are too long or have too many bends with an inducer assy that is aging or secondary exchanger blockages.
By leaving it off you are eliminating a safety control so "Yes" it is a safety concern.
how is offline   Reply With Quote
Old 11-03-2012, 12:23 AM   #3
I checked the vent pipes. They are a long run of about 50feet out the side of the house. I ran a metal wire fish tape and found no obstructions. I have a pressure switch on order, so after install if it fires up is there anything else I should checkout.
Old 11-03-2012, 01:56 AM   #4
how
Tell us what furnace make & model you have. A photo will also help us see what hose set up you have.
Do you still have your furnace installation manual which lists exhaust & intake vent size, fitting & length limitations for your unit?
Old 11-03-2012, 08:32 AM   #5
It is a miller/nordyne model m3rl080a. I know I have the manual somewhere I will look. I had issues with where the first vent pipes were installed, and I spoke with miller to make sure I could run vents out the side of the house and the length. There are 3 inch vent pipes now.
Old 11-03-2012, 08:51 AM   #6
An old Tradesmen
Rewards Points: 6,086
Did it work when the pipes were first reran. or didn't work right after the pipes were reran.
Old 11-03-2012, 08:52 AM   #7
No it has worked fine for 5 years. It just started having this problem
Old 11-03-2012, 08:56 AM   #8
Is it a bad pressure switch?-image.jpg. This photo has tube by gas valve not connected which lets furnace work
Old 11-03-2012, 08:57 AM   #9
Is it a bad pressure switch?-image.jpg this photo has everything connected the correct way
Old 11-03-2012, 08:59 AM   #10
An old Tradesmen
Make sure hoses to pressure switches don't have water in them. And that the posts those hoses are on don't have corrosion on them. Also make sure your condensate drain trap is not restricted.
Old 11-03-2012, 01:09 PM   #11
The small tubes that go to pressure switch are clear. The condensation tube looks like there is water in it, but I took it off and blew air threw it and didn't have resistance.
Old 11-03-2012, 02:18 PM   #12
An old Tradesmen
It could be a bad switch, you might want to try a new one. But you might want to make sure nothing is restricting the vent pipes first.
Old 11-03-2012, 02:39 PM   #13
Hvac Pro
yuri's Avatar
Rewards Points: 1,096
check the ports where the press switch hoses attach to the collector box and burner box for blockage by sticking a drill bit thru. remove the burner box cover and check where the intake pipe attaches, it may have a screen there and leaves or debris may be on it and blocking the air. DO NOT ever run it without the tubes attached or the burner may overfire or burn dirty and seriously damage the furnace and that is VERY dangerous to do!
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Well Pressure Switch Replacement (Photos) porkfriedrice Plumbing 4 10-27-2011 05:31 PM
Help with Amtrol Digital well pressure switch Cool_CA Electrical 1 06-14-2011 08:53 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
