Bad Motor Or Capacitor Going Bad - HVAC - DIY Chatroom Home Improvement Forum
Old 10-21-2008, 09:39 AM   #1
Bad motor or capacitor going bad
I have a 12 year old Lennox furnace but the blower motor was replace 3 years ago. When I run the motor on manual I have the usual start hum and everything sounds fine. When I run it with the AC it seems to hum for a bit and then sounds OK, then will hum again. When I run it with heat it is ungodly loud. Is this simply the motor going belly up already or could a run capacitor that is weak cause a motor to run poorly on low speeds?
thenewton is offline   Reply With Quote
Old 10-21-2008, 12:13 PM   #2
As I recall capacitors decay exponentially, so if you back-probe your capacitor for voltage, power the fan on and off and it does not decay properly then it may be the problem.
dac122 is offline   Reply With Quote
Old 10-21-2008, 10:37 PM   #3
An old Tradesmen
Rewards Points: 7,268
And curse up a storm when you get hit with close to 370 volts from the cap.
Old 10-21-2008, 11:12 PM   #4
If it's just starting the inrush current will blast his "O"ring thru the seat of his pants!
hvaclover is offline   Reply With Quote
Old 10-21-2008, 11:15 PM   #5
I repectfully submit to you that you change the meter setting to capacitance and read the cap's Micro farad value.
Old 10-22-2008, 08:01 AM   #6
Yes, please disregard. Its probably not worth your time to test it.
Old 10-22-2008, 09:31 AM   #7
Oh,it's very well worth the time to check it, but safely.
