Bad Humidistat - HVAC - DIY Chatroom Home Improvement Forum
Old 02-04-2015, 10:11 PM   #1
Rewards Points: 2
Bad Humidistat
I have an Aprilaire Humidifer Model 440 that could be fifty years old. The humidistat is not working. On this model The humidistat is a large mechanical slide that is inserted into the side of the cold air return duct. It appears to measure the humidity on a peace of tape connected to springs and a switch. My question is can I replace this unit with a modern electrical type? I have removed a spring in the humidistat unit to trigger the switch to open the valve thus allowing me to manually control the humidity.
Thank You
murphdiy is offline   Reply With Quote
Old 02-05-2015, 01:38 AM   #2
Rewards Points: 332
Send a message via Yahoo to curtd
Bad Humidistat
Very interesting question. Commenting to follow
curtd is offline   Reply With Quote
Old 02-05-2015, 04:23 AM   #3
An old Tradesmen
Rewards Points: 9,090
Bad Humidistat
You can use another mechanical humidistat. Or if you want to do some rewiring, you can switch to a digital humidistat. Digital ones require a common wire to be ran to them.
Honeywell HE120 Humidifier Humidistat Not Working Properly jobondur HVAC 2 01-16-2013 08:22 PM
Basement humidity affect on Humidistat? mbear2k HVAC 0 12-27-2010 01:56 PM
humidistat malfunction toejam HVAC 2 11-20-2010 08:55 PM
Is this Aprilaire digital humidistat working right? Studly HVAC 6 03-17-2009 03:29 PM
Switched Outlet with humidistat. Clutchcargo Electrical 3 06-21-2007 05:20 PM
