Bad Gas Valve? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-11-2009, 05:35 PM   #16
An old Tradesmen
Rewards Points: 6,570
Really should have called back Sears, when it stopped working the next day.
Same with the other company.
There should be a diagram on the blower door. If its gone. Lots of those old diagrams are not around on the internet.
Old 12-11-2009, 07:43 PM   #17
I have looked on the internet and only found some email addresses that say they have them.
I do not see any information to wire a basic 5 post 24v relay
Honestly I think I just need to know about the RED and Com on the thermostat wiring
do red and COM have power from the 24v tranformer
1 hot to each post RED and COM?
luvheat is offline   Reply With Quote
Old 12-11-2009, 08:40 PM   #18
An old Tradesmen
R of stat is fed from R of transformer.
C of stat is connected to C(common, its not a hot) of transformer.
Don't keep assuming.
Or you will burn up more stuff then you care to replace.
You may be better off biting the bullet on this one. And calling a service tech in.
Old 12-11-2009, 08:47 PM   #19
Hvac Pro
yuri's Avatar
Rewards Points: 1,452
AND if it is done incorrectly and you bypass a limit control or weld it shut someone may DIE and you get sued!!
Old 12-11-2009, 08:52 PM   #20
Question
going to call a tech
Old 12-11-2009, 08:57 PM   #21
An old Tradesmen
No. It should go to what ever controls ignition.
Old 12-11-2009, 09:02 PM   #22
....... nevermind
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
