Bad Furnace Install - HVAC - DIY Chatroom Home Improvement Forum
Old 01-07-2011, 03:54 PM   #1
Bad Furnace Install
Hi:
We bought a foreclosed house that the bank had a new furnace installed in on 2/1/2010.
It is a single stage high efficiency forced air furnace.
The "licensed contractor" who installed the furnace never hooked up the air intake pipe to the outside. It is just sucking in heated air from the basement.
I know this is not "unsafe," but it does lower the efficiency. Is it even legal for a licensed HVAC contractor to neglect this?
If so - I'll call back the company that installed it and have them do it right.
Thanks for the advice.
blakeasaurus is offline   Reply With Quote
Old 01-07-2011, 03:59 PM   #2
check with the local building dept or city hall.
hvaclover is offline   Reply With Quote
Old 01-07-2011, 05:11 PM   #3
Some can use inside air for combustion and others can not. If it passed inspection then yours is approved for inside combustion air being used.
Old 01-07-2011, 05:23 PM   #4
Experienced
Jackofall1's Avatar
This may help
http://www.homeenergyresourcemn.org/...5994&pRID=5959
I would think that you will need combustion air, just my opinion.
Old 01-07-2011, 05:29 PM   #5
I misread you first post. if it is PVC pipe than YES it must be hooked up unless the new furnace was rated as a one pipe system.
But even so they would have been responsible to remove the old pipe and patch the opening in the wall,
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Installing a new Furnace, Shoud I install an A/C Coil Now? hartkem HVAC 1 11-10-2008 09:31 AM
How to install an expansion tank in my hot water furnace? DanBress HVAC 18 10-08-2008 03:57 PM
