Bad Elec. Solenoid On Top Of Furnace Gas Valve With Spark Ignition - HVAC - DIY Chatroom Home Improvement Forum
Old 11-18-2011, 11:09 PM   #1
Bad elec. solenoid on top of furnace gas valve with spark ignition
Can I replace elec. solenoid on furnace gas valve. The solenoid is easy to remove.The part number C54450reve J5 08-07. It is a Robertshaw gas valve with external 24 volt electric solenoid. Jerry
jerrybrumley is offline   Reply With Quote
Old 11-19-2011, 05:37 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
no, you should never take apart a gas valve for repair!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 11-19-2011, 11:06 AM   #3
Robertshaw gas valve 7000
This gas valve does not come apart. It has a replaceable electric solenoid with a snap on plastic cap on top of the valve. The coil sits on the gas valve under the cap it is not inside of it. The gas valve is brand new never used, but it is out of warranty. There was a recall on this heater because of the bad coil. Anyone know where I can purchase this coil. The part # on the coil is C54450REVE J5 08-07, The gas valve is a Robertshaw 7000 and 2000DER series. I can not get Robertshaw Tecs or Reps to return my phone calls. P.S The coil has no OHM's reading. 24 volts to it does nothing.
Old 11-19-2011, 11:50 AM   #4
30 years of fixing furnaces, i have NEVER taken a gas control valve apart,
I am pretty sure the AGA (American gas association) would frown on what you are proposing to do.Is the risk you are taking with your life, your family's life and possibly surrounding structures and lives worth the cost of a new valve?
harleyrider is offline   Reply With Quote
Old 11-19-2011, 09:07 PM   #5
Rewards Points: 582
no no no do not take valve apart.......ever never
Old 11-19-2011, 09:16 PM   #6
how
Rewards Points: 1,098
Never done it. (manufacturers, distributers, gas safety board,) have said No! to residential field gas valve repairs with all manner of dire warnings for as long as I've been swinging wrenches.
how is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Intermittent pilot spark ignition question cody69 HVAC 4 02-16-2011 09:21 PM
Problem with old Rheem furnace ignition Troublefix HVAC 7 02-02-2011 04:52 PM
Leaky furnace valve billinak HVAC 9 11-01-2009 08:11 PM
This may help someone with carrier ignition problems AweMan HVAC 15 02-09-2009 02:20 PM
