Bad Control Board? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-12-2009, 09:09 AM   #1
bad control board?
would a bad board on a american standard freedom 90 still allow furnace to work but other add on not? like humidifier & air cleaner? power to both but neither runs?
cinders is offline   Reply With Quote
Old 12-12-2009, 09:35 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,290
How did you check the power to both? with a volt meter and to ground?. Sounds like the neutral from them may be loose/disconnected and that may not have anything to do with the board.
Old 12-12-2009, 10:02 AM   #3
I have both hooked to separate plug since outlet on furnace does not have power running through it? and no luck!
Old 12-12-2009, 10:51 AM   #4
Hvac Pro
yuri's Avatar
Sounds like you need an electrician or tech to check the wiring.
Carrier furnace control board - OEM or ICM ? anku HVAC 13 10-12-2012 10:50 PM
Goodman 4 flashes on control board bigmac71201 HVAC 6 09-28-2009 02:53 PM
HELP? Control Board Fixed Heat...But Now A/C Won't Turn On - Homeowner KLR HVAC 35 08-15-2009 10:46 AM
Blower control board mlmaher HVAC 1 11-24-2007 01:39 PM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 09:33 PM
