Bad Compressor Or Bad Capacitor - HVAC - DIY Chatroom Home Improvement Forum
Old 07-27-2008, 12:29 PM   #1
Rewards Points: 12
Bad Compressor or Bad Capacitor
I've got an old (very old) Lennox AC. The outside fan starts for a few seconds, appears to be spinning fine - with no alarming noise, but then shuts off. This recurs over and over if the AC is left on. If the fan is running, does that mean the compressor is running? How do I know if the compressor is bad or a capacitor is bad. If capacitor, how do I know if it's the run capacitor or the start capacitor?
I'd appreciate any help. Too cheap to buy a new unit if I can help it.
needhelpbad is offline   Reply With Quote
Old 07-27-2008, 01:02 PM   #2
oops, did I do that!
You could be cycling on one of your limits, high or low. High pressure safety, could be a dirty condensor, lots of heat at the outdoor unit. Low pressure safety, could be low refrigerant charge.
If the motor or compressor were bad, one or the other would continue to run, and you would hear it. Both are energized by the same relay, or contactor. If both are coming on and off together, its probably a safety.
Clean the condensor as best you can. If it needs refrigerant, you will have to call a service co..
Good luck.
8 Ball is offline   Reply With Quote
Old 07-27-2008, 03:20 PM   #3
Rewards Points: 12
Good luck.
Thanks for the help. I guess there is still hope.
Tags
ac capacitor , ac compressor shut off
Pump Control test Franklin wkosbob Electrical 96 03-22-2017 04:30 PM
Capacitor Replacement on Central Air unit sn2567 HVAC 6 07-21-2012 02:29 PM
Replacing a Condenser Fan Motor thothtp HVAC 5 06-08-2008 06:30 PM
Maytag Plus Techman2006 Appliances 2 12-12-2007 11:40 AM
Looking for blower motor capacitor dditch66 HVAC 3 11-26-2007 07:35 PM
