Bad Coil? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-27-2010, 06:00 PM   #1
bad coil?
how can i tell if my coil is bad. i hear people saying there coils went out. can i check??? thanks
fishboy1002 is offline   Reply With Quote
Old 06-27-2010, 10:44 PM   #2
Not without a lot of expensive equiptment . Best a home owner can do is take a temp reading between the supply and return. If you have a 17-21 degree difference between the two the coil probably is fine.
Evaporator Coil Sizing kandykane19 HVAC 0 05-05-2010 03:44 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 09:27 AM
Air conditioning coil heat tolerance? Badfish740 HVAC 1 10-19-2009 05:39 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Replacing a 2 ton A coil with a N coil with TX valve englewood1 HVAC 7 09-11-2008 12:09 PM
