Backup Heat Only Switchover - HVAC - DIY Chatroom Home Improvement Forum
Old 12-20-2008, 11:13 PM   #1
Backup heat only switchover
Hi, I live in Montreal, Quebec, Canada, and here people who has an heat pump and oil backup can get a better eletricity price, above -12 celsius. Below that point, electricity cost a LOT more.
I have 2 wires coming from that system, normally closed (above -12 celsius), and open (below -12 celsius). I use them to control my "Y" heat pump wire. It works great. My heat pump will never work below -12.
The problem is that, below -12, my thermostat (Carrier TSTATCCSAC01) will energize the "Y" wire for heat (has no effect, open circuit) , wait 15 minutes, then energize the "W" (oil backup). During these 15 minutes, it's getting cold in the house ! I must manually set the the thermostat to "Emergency heat" to counter this behavior.
How can I tell the thermostat to go directly in oil backup when below -12 ?
Thanks for the help !
hdvd is offline   Reply With Quote
Old 12-21-2008, 05:15 AM   #2
An old Tradesmen
Rewards Points: 6,068
Uou can add an external dual fuel control, that will automatically switch over and use the oil furnace without having to wait for the temp to drop.
Or get a thermostat that is a dual fuel control that will automatically switch over to the oil furnace without having to wait for the temp to drop.
Carrier, Honeywell, and WhiteRodgers all make them.
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 11:22 PM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 04:57 PM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
