Backflow Preventer - M2 Or M3? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-04-2009, 08:38 AM   #1
Backflow Preventer - M2 or M3?
So my Watts 9D backflow preventer valve started leaking out the vent. My question is, how do I know which kind to replace? I found a Watts BFP at the big box store, but it seems too small. I see online there are now M2 or M3 versions, mine just says 9D on it. Any way to see which size I need? I think maybe 3/4", only because the 1/2" size seems like the ends are too small - the nuts that screw on either side of mine are > 1".
velcrobots is offline   Reply With Quote
Old 10-04-2009, 08:53 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,260
There is a DIY plumbing forum at the top of this page, post there.
Old 10-04-2009, 09:12 AM   #3
sorry, figured since it was on my boiler it fell under HVAC, thanks.
Old 10-04-2009, 10:22 AM   #4
Hvac Pro
yuri's Avatar
We have a couple boiler gurus here, check back later.
Old 10-04-2009, 10:49 AM   #5
An old Tradesmen
Rewards Points: 7,356
The nuts. Will be about 1" even on a 1/2" BFP.
You want the vented model. The 9M is not vented.
Before changing it out though. make sure it is defective or leaking without another reason.
Also, most are rebuildable.
I seldom do it because its quicker to change it out on a service call.
Old 10-04-2009, 11:06 AM   #6
Thanks. I went and got a 1/2" cuz that's all the big-box store had, wanted to just get one for size, and it's too small, like i thought. I ordered a 3/4" online, should fit hopefully.
The original was vented. Maybe it just said 9D because it was very old? Not sure.
Old 10-04-2009, 12:20 PM   #7
An old Tradesmen
9D is vented. 9M is not
backflow device on outside faucet claudiaw Plumbing 9 06-01-2012 07:23 PM
Do I Need a Backflow Valve for Hose-Sprinkler? jbk Landscaping & Lawn Care 3 09-29-2009 06:20 PM
Backflow device testing - possible scam? ScottR Plumbing 9 06-14-2009 10:55 AM
backflow in oil/wood system jmancine HVAC 8 10-30-2007 02:17 PM
Crabgrass Preventer cibula11 Landscaping & Lawn Care 7 04-16-2007 02:07 PM
