Backfires -new Goodman 95% - HVAC - DIY Chatroom Home Improvement Forum
Old 12-31-2010, 09:15 AM   #1
Backfires -new goodman 95%
I purchased a goodman furnace on ebay and had what I thought was AC specialist install it. Ran fine (continuously I think) for hours getting the temp from 60 to 70 than began to back fire about a dozen times in the 15 seconds it took for me to figure out what was going on and turn the system off.
Hellp please,
arejohn is offline   Reply With Quote
Old 12-31-2010, 10:21 AM   #2
Read the installation instructions and make sure the venting ,condensate and gas pressures are correct.
Old 12-31-2010, 11:22 AM   #3
dual pipe system. 2" about 20 ft. 5 bends each. Gas company privides 5 gas pressure. Did not see techs check this or system pressure. I suspect back fires occured after end of cycle. COuld something have gotten into the gas valve preventing it from closing completely at end of cycle?
These guys are comming back but I think I am going to have to diagnose this,
They were trying to tell me the gas companys pressure regulater is wrong for this system, I think its BS.
Guess this is what happens when you wait the last minute.
Old 12-31-2010, 11:27 AM   #4
Horizontal installation. I think we got the two condensate hoses correct. But we did not have time to install the water trap. Flue iS flue is tilted towards the unit but I did notice water at the flue exit "T"
u\
i
Old 12-31-2010, 01:15 PM   #5
An old Tradesmen
Rewards Points: 6,112
5 what gas pressure.
5 inches? 5 pounds?
Old 12-31-2010, 02:21 PM   #6
5 inches? 5 pounds?
My short term memory is shot. Only a little better than my long term. So I left it off because I couldn't remember which.
No backfires today but did get E9 high pressure switch open. Diags said check hose. Guess what...hose in wrong place. Adjacent drain hose not there either. It was wrong place too.
Thanks guys. Things are looking up.
Get the champagne
Old 01-03-2011, 06:55 PM   #7
Thanks all. Seems fixing the drains solved the backfires.
Goodman air handler adjustment Xander08 HVAC 2 12-24-2009 03:32 PM
goodman 3ton dhop11 HVAC 2 11-14-2009 01:02 PM
Nordyne condenser goodman A-coil wtroger HVAC 10 09-16-2009 04:52 AM
Replacing an 20 year old gas forced air with a 95% 2 stage goodman, goodman 40" tall, englewood1 HVAC 12 09-26-2007 12:37 AM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 08:54 AM
