B-vent Supports? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-11-2012, 06:15 PM   #1
Rewards Points: 29
B-vent supports?
Hi, I'm running b-vent for a water heater vertically up a wall cavity from a basement to an attic. Are any straps or supports needed in the wall cavity to secure the vent? And if so, how many for an 8' rise?
lmorsino is offline   Reply With Quote
Old 06-11-2012, 07:09 PM   #2
An old Tradesmen
Rewards Points: 6,480
Yes. probably get a way with 2.
Old 06-11-2012, 08:47 PM   #3
Rewards Points: 582
we support every 2.5 foot on the vertical run... I would use 3 may be alittle over kill but its safe....
Old 06-12-2012, 07:03 AM   #4
Rewards Points: 1,216
They make base supports for B vent that keeps the pipe away from combustibles and holds the pipe in place, that's what you need for support and safety. The base tabs fit into the groves on the pipe.
COLDIRON is offline   Reply With Quote
Installing a gable vent..from *inside* the attic steveKane Building & Construction 8 12-09-2012 03:45 PM
Help with basement bathroom vent satchfan Plumbing 3 12-26-2010 10:35 PM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 01:09 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 07:34 PM
