Avanti, Gas Fireplace 1996 - HVAC - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 07:32 PM   #1
Avanti, Gas fireplace 1996
we are having a problem with this freestanding gas fireplace vented. it lights the pilot and the logs after about 10 minutes it goes out. any ideas?
debbyd is offline   Reply With Quote
Old 02-15-2012, 07:48 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Does this fireplace have a blower?
After it goes out will it relite?
It may be overheating
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-15-2012, 11:08 PM   #3
Registered User
Rewards Points: 5,514
Please, only one identical post. This is the best place for your answer, have patience.
Carry on......
Gary
Old 02-16-2012, 12:48 AM   #4
how
Rewards Points: 1,104
The most common cause is a pilot related lockout.
I would check the pilot and thermocouple/powerpile. If the pilot flame is small or soft then the air movement caused by the units heating can pull the pilot flame away from the pilot safety control or the powerpile generator enough to cause a lockout. Clean the thermocoupler/powerpile and use a thin tube to blow out any debris from the pilot hood. When the pilot is burning- rap the pilot assy with a screwdriver (like knocking on a front door)to see if the pilot flame becomes larger or harder. If so then you've probably fixed the problem. If the problem persists and the pilot flame still looks weak then the pilot orifice should be opened up and examined but that is a job better left to a pro.
how is offline   Reply With Quote
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 09:56 PM
Need opinions on tearing out old fireplace Dwillems Building & Construction 9 09-06-2011 11:37 AM
Fireplace Smell ...help wanted ! jasonb72 General DIY Discussions 6 08-26-2010 06:02 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
