Auxilliary Heat Control - HVAC - DIY Chatroom Home Improvement Forum
Old 04-30-2011, 07:24 AM   #1
auxilliary heat control
Heat strips immediately turn on when thermostat is turned up only 2 degrees. This is an electric heat pump system - shouldn't the heat pump be able to handle the heat request for 2 degrees without having the auxilliary heat(expensive coils) turn on?
The indoor temperature was 60 degrees. The thermastat setpoint for heat was set to 55. An outdoor temperature sensor is also configured and the outdoor temperature was about 58 degrees. The thermostat is configured to block out auxilliary heat when the outdoor temperature is above 37 degrees.
13xf fan coil - electric - international comfort products - model: nfcx3600c1
heat pump - electric - international comfort products - model: TCH430AKA1
tstats - brand new carrier "Edge" non-programmable - TPNRH
outdoor temp sensor - TSTATXXSEN01-B
JeanThomas is offline   Reply With Quote
Old 04-30-2011, 09:29 AM   #2
An old Tradesmen
Rewards Points: 8,172
Doesn't sound like its configured right, if the aux came on when it was 58 outside.
Tags
auxilliary heat , nfcx3600c1 , tch430aka1
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 03:59 AM
Heat Pump Thermostat HELP!!! MichaelG HVAC 22 12-09-2010 04:50 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
Which honeywell thermostat should I buy for my Carrier heat pump? mannypp HVAC 29 01-30-2010 02:21 PM
