AUX Not On In Defrost - HVAC - DIY Chatroom Home Improvement Forum
Old 11-12-2014, 07:33 PM   #1
Rewards Points: 6
AUX not on in defrost
Hi guys,
I have a relatively new split Trane system. It worked well in the summer. Now since it got colder (close to 32 degrees), it goes into a defrost mode but the aux light on the thermostat does not come on and I wonder if something is not connected right or it is normal when the inside temperature is high enough not to warrant the aux? I would really appreciate your help. Aux by itself works fine (for example, when I put the thermostat 3 or more degrees higher that current temp). So it works in regular mode.
Or can it also be that with this thermostat aux is on in defrost but it is just not showing on display? I checked the air during defrost and it not really cold but not warm either. Like from a fan.
My thermostat is Honeywell FocusPRO 5000.
Seech is offline   Reply With Quote
Old 11-12-2014, 07:41 PM   #2
Rewards Points: 3,256
When it goes into defrost, is the air out of the registers cold like A/C or warm? If warm, my guess is that the thermostat is not designed for the aux to light up in defrost.
zappa is offline   Reply With Quote
Old 11-12-2014, 07:51 PM   #3
Rewards Points: 6
It is not ac cold, but not warm either.
Old 11-12-2014, 08:03 PM   #4
It sounds OK, they call it tempered. Unless someone sez otherwise I don't believe the aux indicator is supposed to come on.
Old 11-13-2014, 05:20 AM   #5
An old Tradesmen
Rewards Points: 6,112
Your strip heaters may be staged/separated. Its possible that your thermostat is wired to bring on 10KW of aux heat. And your heat pump is wired to bring on 5KW of strip heat that is not connected to the thermostat.
In defrost, if the strip heat is not coming on, the air will be very cold. 15 or more degrees colder then the inside air.
Old 11-14-2014, 01:43 PM   #6
Rewards Points: 6
Thank you both for your answers. I hope then my system works as it should.
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 09:21 AM
Tempstar heat pump won't initiate defrost cycle lgmccoy1 HVAC 14 12-08-2011 07:07 PM
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 06:51 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 09:13 PM
Kenmore fridge not cooling, freezer ok bobvanhalder HVAC 7 10-22-2008 11:52 PM
