Aux Heat Not Working With Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 10-26-2011, 12:29 PM   #1
Aux Heat Not working with Heat Pump
I'm hoping someone on here can give me some help because this problem has been driving me crazy for over 3 years.
We have a new construction house that is now 3 years old. We have a heatpump system with a NG furnace as the aux/backup controlled by a honeywell 8320 thermostat.
Heatpump works flawlessly for 10 months out of the year but once the outside temp gets below 30 the heatpump turns off and the aux doesn't start. If I select the "EM Heat" setting then the furnace will work properly.
I would like the furnace to come on as an auxillery heat while the HP is still running or at the very least switch the HP off and turn the gas furnace on.
I have went into the installer settings and changed the balancepoint to 25 instead of 30 which should keep the HP running a little longer, but still doesn't solve the core problem.
Here is the photo of the wiring:
It is a little hard to see but from what I have read already is that I could jumper the "E" wire to the "AUX" wire and things should work as I expect; however, there is already a black wire running the "AUX".
I'm temped to disconnect the black wire and jumper the white wire to the AUX terminal and see what happens.
Thanks in advance for any help.
UPDATE: So I decided to put a jumper into place between the E and W2 terminals. This worked kindof. When putting the thermostat into test mode and attempting to engage the aux heat the heat pump turned off, air handler turned off, furnace fired, air handler turned on. Overall this is a workable solution, but my ideal solution would be for the heat pump to remain on and just have the aux be supplemental until the thermostat reaches the desired temp.
quamism is offline   Reply With Quote
Old 10-26-2011, 04:01 PM   #2
Just an update:
Seems like my jumper fix did the job as the furnace and the HP can't run at the same time.
Old 10-26-2011, 05:17 PM   #3
An old Tradesmen
Rewards Points: 6,140
What model number is that thermostat?
Old 10-26-2011, 05:34 PM   #4
Rewards Points: 6,652
Old 10-26-2011, 05:38 PM   #5
An old Tradesmen
I missed that whole sentence.
Old 10-26-2011, 05:40 PM   #6
An old Tradesmen
Post your installer set up settings. Don't need a jumper from E to W2 for it to work.
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 06:51 PM
Carrier Heat Pump stopped working burnselk HVAC 2 02-06-2010 01:30 AM
Which honeywell thermostat should I buy for my Carrier heat pump? mannypp HVAC 29 01-30-2010 03:21 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
heat pump not working kyleGR HVAC 2 05-30-2006 03:35 PM
