Old 11-06-2009, 03:05 PM   #1
zep
Default Aux heat during Defrost mode.
4 ton heat pump with VS air handler
The auxiliary heat does not energize in defrost mode. 2nd stage heat does energize when called for. In addition, Emergency heat works as well. Any ideas where to begin the troubleshooting process?
zep is offline   Reply With Quote
Old 11-06-2009, 07:12 PM   #2
is the sequencer or contactor being energized is the heat strip good and not burned out
mrairflow is offline   Reply With Quote
Old 11-06-2009, 08:08 PM   #3
It's simple. When a HP goes into defrost mode it's control board energizes a 24V defrost signal. You just need to tie this signal to the 2nd stage heat terminal at the air handler.
Some contractors don't bother providing for 2nd stage heat during defrost. It's really optional. Defrost doesn't last very long.
hennyh is offline   Reply With Quote
Old 11-06-2009, 08:37 PM   #4
Start by checking the wiring from heat pump to air handler as it is up to the heat pump to initiate defrost mode.
dac122 is offline   Reply With Quote
Old 11-08-2009, 06:07 PM   #5
zep
This was exactly the case. I discovered that the W2 wire was not hooked up from the defrost board to the air handler. Thanks for the tip.
Old 11-08-2009, 10:35 PM   #6
You're welcome. Glad it was this simple.
More On This Topic
So now we are going to go over Aeolian which is our 6th mode, 6th degree of the scale. So C is 6th degree of E flat major. Do E flat major 1, 2, 3, 4, 5, 6 so that is our basic pattern. So just like our minor pattern but we have this flat 6 in there now... Read More »
Modes in F: Aeolian
Modes in F: Aeolian by Expert Village
So now we are going to over our F Aeolian chord. Aeolian is the 6th mode of the major scale so F is the 6th degree of A flat major. So we are going to be looking at A flat major scale. So we are going to go through and look at it first. So we are A flat... Read More »
Modes with Root Gb: Ionian
Modes with Root Gb: Ionian by Expert Village
Now we are going to go over our modes with the root of G flat. There are 7 modes so I'm going to show you the modes as they protein to G flat major but as we go through and actually look how they altered the G major scale. So we are going to keep the... Read More »
Modes with Root Gb: Aeolian
Modes with Root Gb: Aeolian by Expert Village
Now we have our Aeolian scale which is the 6th degree of the major scale which is derived out of A major. If we are using G flat as our root, A major 1,2,3,4,5,6 and G flat. So now we play the A major scale starting on G flat. And you have a regular G... Read More »
Now we are going to look at E aeolian which is the 6th mode our of G major and what it basically is the E minor chord in has that minor quality but it has a flat 6 in there. You can hear that flat 6 really clashes so you don't want to use it cordially... Read More »
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 11:27 AM
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 6 07-27-2009 05:02 PM
Carrier Comfort Zone - NO HEAT WhackAMole HVAC 0 05-06-2009 08:34 AM
Goodman Heat Pump defrost noise RCApp HVAC 1 12-17-2008 08:54 AM
GE Electric Dryer won't shut off in auto/high heat mode jktbnelson Appliances 6 02-19-2008 10:55 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
