Old 03-13-2010, 11:50 AM   #1
Aux heat doesn't come on during defrost cycle
Hello-
We have a Rheem Heat pump model RPMD-060-JAZ. We have a two stage furnace as back up heat. When the heat pump goes into the defrost mode the auxiliary heat doesn't kick on. (blows cold air and system kicks into secondary heat prematurely)
Anyone know the correct wiring for the desired operation?
I've looked at the wiring diagram for the heat pump and the wiring outside at the heat pump: the PR wire and the Y wire at the heat pump are combined with a wire nut and then connected to the thermostat Y wire. The heat pump wiring diagram has a note next to the PR wire saying it is used to turn on strip heat during defrost.
Any help is appreciated.
hesse is offline   Reply With Quote
Old 03-14-2010, 04:07 AM   #2
An old Tradesmen
That would be the wire that should be connected to W1 of the furnace.
The Following User Says Thank You to beenthere For This Useful Post:
hesse (03-14-2010)
Old 03-14-2010, 09:21 AM   #3
Thanks for the Info. I'll separate the Y and PR wires at the Heat pump and run the PR wire to W1 of the furnace.
Thanks again!
Old 03-15-2010, 06:24 AM   #4
An old Tradesmen
No problem, your welcome.
Old 03-17-2010, 09:32 PM   #5
FYI- It worked.
Old 03-18-2010, 05:10 AM   #6
An old Tradesmen
Good. That cool air during defrost isn't always nice.
Now you can stay warm during defrost, take care.
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 9 03-22-2011 09:40 PM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
VisionPRO Setup Functions & Heat Pump infoskr HVAC 31 03-18-2010 02:15 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 09:13 PM
Adjusting Heat Pump Defrost Cycle chip19474 HVAC 1 02-01-2010 10:10 AM
