Automotive HVAC Equipment Converted For HVACR - HVAC - DIY Chatroom Home Improvement Forum
Old 08-08-2010, 02:08 PM   #1
Rewards Points: 81
Automotive HVAC Equipment converted for HVACR
I appreciate all the help you guys give. Sorry for all the questions but I am trying to get everything in order before I try to install my xb14 trane condenser. I normally work on automotive AC so I hope I can use some of my equipment to charge my 410a system. I posted a spec sheet of the vacuum pump that I use and my gauge set below. My r134a gauge only goes up to 500 pis on the high side. Is this high enough? I can just use the PT chart to get the temperature for r410a since my gauge only has r22 and r134a temperatures. I have an automotive hose set and unscrewed the quick connect coupler off the end to see what thread the hoses are. I am not sure if I can converter the hoses for use with r410a? What size threads are used for r410a service fittings? If I cant convert the hoses I could probably just by a hose set for my gauges if 500 psi is high enough.
Automotive HVAC Equipment converted for HVACR-img_2333.jpg   Automotive HVAC Equipment converted for HVACR-img_2335.jpg   Automotive HVAC Equipment converted for HVACR-img_2337.jpg
hartkem is offline   Reply With Quote
Old 08-08-2010, 04:06 PM   #2
An old Tradesmen
Rewards Points: 6,548
Considering that R410A is at 102PSIG at a saturation temp of 32F. Your gauge isn't going to cut it.
Standard residential split systems use 1/4" flare threads.
You should also be using a micron gauge to know when he vacuum is low enough.
Its very hard to see the difference between 29.1 and 29.6" mercury vacuum, on compound gauges.
Old 08-08-2010, 09:42 PM   #3
Rewards Points: 81
Ok, so it looks like I will need to get a dedicated gauge for r410a. Since I won't be doing this often can't I just pull a vacuum on the system for like 2 hours. I realize the micron gauge is the best way to do it and I would have no problem buying one if this was what I did for a living. Anyone recommend a low cost decent r410a gauge set for casual use. I see some on ebay. Any reason to get a 4 way manifold?
Old 08-08-2010, 10:23 PM   #4
An old Tradesmen
You can vacuum for 2 hours. And not know if it was low enough or not. Do you know any HVAC techs that will come over and use theirs.
4 way manifold is good for charging and vacuuming.
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
Disconnect on HVAC equipment hvaclover Electrical 16 02-27-2009 07:47 AM
Buying HVAC Equipment EarthCreepin HVAC 3 08-01-2008 10:00 PM
HVAC Equipment Outlet BigJimmy Electrical 3 01-01-2008 08:02 PM
