Automatic Fan Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 03-02-2009, 12:11 AM   #1
Automatic Fan not working
My heat works, and I can turn the fan ON, but if I adjust the thermostat to automatically switch on and off, the fan never comes on, leaving the larger rooms in my home chilly.
Also, the thermostat is heating up higher than what I set it to, because it can't bring the temperature to where it needs to be. Not only will my gas bill be high, but I'm concerned about a fire.
Will I need to replace the entire circuit board, or can I just replace a fuse or something?
And is this something I should fix, like, immediately?
elbryan is offline   Reply With Quote
Old 03-02-2009, 05:41 AM   #2
An old Tradesmen
Rewards Points: 6,498
If its heating up higher then what you set it to, then it bringing up the heat.
Post brand and model number.
Old 03-02-2009, 06:28 PM   #3
It's a Lennox.
The Model Number is partially covered up, so all I can read is C16-4.
The problem is with the automatic fan. I think the heat is running harder to heat the home because the fan isn't spreading the warm air.
Could it be an issue with the thermostat not registering the temperature rather than and issue with the actual heater itself?
Old 03-02-2009, 08:07 PM   #4
An old Tradesmen
The thermostat doesn't control the fan.
Have you changed your air filter lately.
If you have central A/C, it could be that the coil is dirty.
Do you have any returns blocked.
Light & switch not working jgayle Electrical 1 01-18-2009 06:28 PM
side by side light swithes not working katkell2645 Electrical 2 10-17-2008 08:22 PM
Inside Fan not working BenH HVAC 20 07-08-2008 07:10 AM
Working with granite... SDeeter19464 Remodeling 5 06-14-2008 06:51 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 02:47 PM
