My heat works, and I can turn the fan ON, but if I adjust the thermostat to automatically switch on and off, the fan never comes on, leaving the larger rooms in my home chilly.
Also, the thermostat is heating up higher than what I set it to, because it can't bring the temperature to where it needs to be. Not only will my gas bill be high, but I'm concerned about a fire.
Will I need to replace the entire circuit board, or can I just replace a fuse or something?
And is this something I should fix, like, immediately?
:furious:
:furious:
