Old 01-31-2011, 02:46 PM   #1
Auto Rollout switch
I haven't had to reset my manual rollout switch lately on Bryant 345MAV048100ACKA so that's good but I'm thinking to change it now to an "auto" reset and maybe save a trip out there in the future.
I found part #HH18HA211, which opens at 225 degree and closes at 175.
Of course I'd be concerned I wouldn't know something is making it trip that needs attention...but on the other hand it resets itself so...any opinions on using this part, and does that temperature range seem right for my unit? Appreciate all the help...you guys rule!
TruckTahoe is offline   Reply With Quote
Old 01-31-2011, 05:36 PM   #2
Professional
Auto Rollout switch
NO!!! A roll out switch should be manual reset only. if it is tripping there is something wrong!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-31-2011, 07:53 PM   #3
Hvac Pro
Auto Rollout switch
Will void any house insurance if a fire occurs. Voids the UL and CGA/AGA gas certification of the unit also.
Old 01-31-2011, 08:36 PM   #4
Auto Rollout switch
Thanks guys for confirming my fears, I won't be installing this auto switch. Waking up on fire is never a good thing
Old 01-31-2011, 08:50 PM   #5
An old Tradesmen
Auto Rollout switch
Remember, the switch tripping isn't the problem. What is causing it to trip is the problem. look for and cure the cause, not the symptom.
Old 01-31-2011, 08:56 PM   #6
Auto Rollout switch
I had the condensation backing up and cleaned out hoses, replaced a kink one, got all the water out...I think that was tripping it before. Had pros come out also and they set the fan speed down a notch and showed 120 degrees in the vent leaving the unit and near that up above at the closest register and said that was good.
Old 01-31-2011, 09:02 PM   #7
An old Tradesmen
Auto Rollout switch
Be prepared for it to trip again.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Double switch wiring rockclimber Electrical 18 03-18-2012 11:13 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 03:17 AM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 09:00 PM
