Auto Isn't Working On My System - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-09-2012, 10:44 PM   #16
Rewards Points: 614
thats the hi limit..... what did he say was wrong ....... its old but if its safe and you do not mind throwing money out the chimney let's see if we can fix it....
carmon is offline   Reply With Quote
The Following User Says Thank You to carmon For This Useful Post:
mrairflow (11-10-2012)
Old 11-09-2012, 10:57 PM   #17
Rewards Points: 27
He said it was the limit & thermostat. Previously, he had given the $600 - $700 estimate to my wife. I'm going to have a guess that changing that part out shouldn't be anything as costly as that. I know that in an ideal world, I would replace everything. But right now, 4k .......
Thanks for the reply, I appreciate it.
Hugh
hugh71158 is offline   Reply With Quote
Old 11-09-2012, 10:59 PM   #18
Rewards Points: 614
the limit should be no where near 700.....
Old 11-09-2012, 11:19 PM   #19
Missouri Bound's Avatar
So what did you decide to do? Did you pay him that crazy amount or find another tech. It's a $300 to $400 job at best. Maybe 1 hour.
Do you want it your way or the right way?
Old 11-10-2012, 05:28 AM   #20
An old Tradesmen
Rewards Points: 6,116
The device on the left is the limit that prevents the burner from running. The device on the left is what runs the fan during a heat call when the thermostat is in the fan "auto" mode.
Old 11-10-2012, 10:31 AM   #21
Rewards Points: 27
I didn't do anything. Prices were left for a total replacement.
Beenthere - you said they are both on the left. Can you clarify which is which. (bearing in mind my system just isn't working on auto) May I also ask, any reason why I shouldn't just source the part and fit it myself?
Thanks!!!!
Hugh
Old 11-10-2012, 10:36 AM   #22
An old Tradesmen
LOL.. left is limit switch, right is the fan control.
No problem with you swapping out your own parts.
Old 11-10-2012, 10:38 AM   #23
Rewards Points: 27
Excellent - and thanks again. I found the article below, that will help a lot.
Hugh
http://inspectapedia.com/heat/Fan_Li..._Procedure.htm
Old 11-13-2012, 04:09 PM   #24
Rewards Points: 27
So, I decided that before changing parts myself I would get a second opinion.
Guy came out, agreed that the fan limit was not working. He cut a section out if the casing and checked the heat exchanger - and reported that he was surprised that a unit fitted when the house was built, 1972, had no cracks.
He also checked for the dangerous levels of carbon monoxide the previous guy reported, insisting that the system should NOT be switched back on - and found absolutely none!!!!
So, new switch fitted, everything working just fine - $310.
Thank you all for your help. :-)
Old 11-13-2012, 06:37 PM   #25
Rewards Points: 196
The part on the left is high temp limit,on the right is fan control.Fan control has been replaced,with a more modern fan/limit control but only fan control side is being used.To me it sounds like the fan center that is on the outside of furnace isn't wired properly.Power should be coming out of fan control,then into normally closed contacts in fan center then to the fan motor.Sounds like this is where you might be wired wrong.Fan center is added when ac was installed.
HVACTECH96 is offline   Reply With Quote
Old 11-13-2012, 06:40 PM   #26
Rewards Points: 196
Sorry.Cant type fast and I just seen your latest post.
Old 11-17-2012, 06:34 PM   #27
Rewards Points: 27
No problem - thanks
Old 11-17-2012, 10:51 PM   #28
24v residential stat diagram
<a href="http://tinypic.com?ref=2wokfb8" target="_blank"><img src="http://i45.tinypic.com/2wokfb8.png" border="0" alt="Image and video hosting by TinyPic"></a>
Chimmy is offline   Reply With Quote
Old 11-17-2012, 10:54 PM   #29
24v stat wiring diagram
Old 11-17-2012, 10:58 PM   #30
The time delay controls low/heat speed
<a href="http://tinypic.com?ref=2h4er7l" target="_blank"><img src="http://i45.tinypic.com/2h4er7l.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
While the fan relay runs high or cool speed
If in heat mode the temp delay is bad, if you have a time delay or time/temp delay same goes for therm.
Need help with finishing touches on radiant heat system gbwillner HVAC 6 12-03-2011 12:16 PM
Need advice RE: purging air from baseboard hot water heating system mikenri HVAC 2 01-19-2011 08:17 PM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 06:23 PM
Kinetico Water Softeners -Reverse Osmosis Questions...Help - Advice wanted.. OverRunWithSons Plumbing 7 07-26-2009 01:14 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
