Audible Condensation Drops In Water Heater Type B Horizontal Venting - HVAC - DIY Chatroom Home Improvement Forum
Old 06-06-2012, 12:37 PM   #1
Rewards Points: 1,062
Question
audible condensation drops in water heater type B horizontal venting
i can occasionally hear a few drops here and there in my 3" type B horizontal (well, mildly sloped but certainly more horizontal than vertical) venting for my gas water heater, which runs about 8-9 ft from the appliance to the vertical rise into the chimney with a total of 3 90 deg elbows.
i was wondering if this is expected behavior or whether it is a sign of the vent being too long to allow the fumes to condense.
thanks
Old 06-06-2012, 02:33 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Your problem would appear to be that the exhaust fumes are condensing in the pipe.
Put more of a pitch on the pipe. What's going to inevitabley occur is sediment will build up and block the inducer port, resulting in your furnace not firing up.
Not to mention horizontal is not proper installation, not even for on inch of vent pipe.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
amakarevic (06-06-2012)
Old 06-06-2012, 02:35 PM   #3
If that means cutting a hole in the roof so you can run the pipe closer and with more of a pitch and installing flashing as well as having a roofing company come out and patch the old hole than so be it.
Or you could move the entire unit. Just get more of a pitch somehow.
Thanks.
Old 06-06-2012, 02:40 PM   #4
My fault, not a gas furnace, a gas water heater. No draft inducer.
Thanks.
Old 06-06-2012, 03:30 PM   #5
Originally Posted by Doc Holliday View Post
Put more of a pitch on the pipe. .
impossible. tight ceiling space. with everything that stands in the way, it would be like a $30K project. it would be cheaper to replace the water heater every year perpetually (for the duration of my stay in the house).
Tags
condensation
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 11:36 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
