Attractive Floor Vents That Don't Compromise Air Flow? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-05-2012, 07:30 PM   #1
Rewards Points: 156
attractive floor vents that don't compromise air flow?
I'm in the process of having a new ductwork system put in. A complete tear out and replacement, new design, new everything. I'm told that the wood grates I have now compromise airflow. Problem is, the light oak color goes perfectly with my wood floors and I really don't want to put in some less attractive vents.
Anyone have any suggestions?
strategery is offline   Reply With Quote
Old 09-05-2012, 07:35 PM   #2
You'd have to upsize the ducts to get back the restriction.
Or at least the boots.
Evstarr is offline   Reply With Quote
Old 09-05-2012, 07:35 PM   #3
Rewards Points: 13,270
Since we do not even know what your's look like it's hard to say.
Did they also offer to sell you some new one at an added cost?
Lowes and Home Depot both have a whole display of brass, metal, and wooden defusers.
Old 09-05-2012, 10:59 PM   #4
Rewards Points: 156
They didn't offer to sell new ones. They just recommended I replace my wooden ones with regular metal ones. They claim the wood ones restrict airflow.
Old 09-06-2012, 05:46 AM   #5
An old Tradesmen
Rewards Points: 6,476
They are correct.
Old 09-06-2012, 08:25 AM   #6
Rewards Points: 1,216
I can see the wood product restricting some air flow it can't be that much more. Flow measurements would have to be taken to see the difference.
I would use whatever I liked that look good and matches the decor.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 09-06-2012, 08:33 AM   #7
angelatc's Avatar
IF you're the crafty type, you could use the metal type and paint a faux wood finish on them.
angelatc is offline   Reply With Quote
Old 09-06-2012, 10:15 AM   #8
Quote removed due to non related text......
Last edited by COLDIRON; 09-06-2012 at 10:20 AM. Reason: Removed Quote because no related to issue...
Old 09-06-2012, 05:28 PM   #9
An old Tradesmen
20% minimum reduction in air flow for the least resistive wood floor supplies. 40% on many of them.
A 4X10 metal often needs to be increased to a 4X14 wood to get the same air flow.
Old 08-09-2015, 08:32 PM   #10
Rewards Points: 892
I know this thread is super old, but I came across it during a search of my own issues involving an HVAC upgrade. I took off all of my custom wood floor registers and REALLY noticed a difference in the coolness of the house.
I'm not kidding!!
Daugela is offline   Reply With Quote
Old 08-09-2015, 08:37 PM   #11
Rewards Points: 7,104
You can get plastic registers which look like wood and seem to flow air even better than the stamped metal ones.
user_12345a is offline   Reply With Quote
Old 08-09-2015, 10:08 PM   #12
Rewards Points: 892
Really?...I'm looking for galvanized ones to give an industrial look, but nobody sells them. How are the plastic ones better? Seems the thin metal slates at the most efficient. Out here in AZ, nobody sells the 6x10 since nobody has floor registers. Need to find online.
Old 08-09-2015, 10:12 PM   #13
I don't know if they're better than stamped metal.
I assume that the stamped registers aren't the greatest - non-stamped metal would be ideal.
Old 08-10-2015, 02:44 PM   #14
HVAC Tech/Owner
Rewards Points: 604
The big box stores sell brass restrictive floor vents and filtrete filters....and everyone calls the AC contractors theives.......
Technow is offline   Reply With Quote
Old 08-10-2015, 04:44 PM   #15
Rewards Points: 2,634
Doesn't seem make sense. Your AC will keep running until your house reaches the temperature on the thermostat. If you didn't change the setting on your thermostat, how can your house be cooler?
SPS-1 is offline   Reply With Quote
I thought I understood plumbing, private well flow rate question ChrisDIY Plumbing 22 07-25-2011 11:14 AM
Moving HVAC ducts/registers & reverse flow ?'s cbrc5eric HVAC 3 06-09-2010 06:05 AM
Flow switch use in Hydronic Heating System sarlaud HVAC 14 02-02-2010 08:03 AM
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-16-2009 12:09 AM
very low shower head flow rickard681 Plumbing 7 10-08-2008 07:43 AM
