-   -   attractive floor vents that don't compromise air flow? (http://www.diychatroom.com/f17/attractive-floor-vents-dont-compromise-air-flow-155957/)
strategery 09-05-2012 07:30 PM
I'm in the process of having a new ductwork system put in. A complete tear out and replacement, new design, new everything. I'm told that the wood grates I have now compromise airflow. Problem is, the light oak color goes perfectly with my wood floors and I really don't want to put in some less attractive vents.
Anyone have any suggestions?
Evstarr 09-05-2012 07:35 PM
You'd have to upsize the ducts to get back the restriction.
Or at least the boots.
joecaption 09-05-2012 07:35 PM
Since we do not even know what your's look like it's hard to say.
Did they also offer to sell you some new one at an added cost?
Lowes and Home Depot both have a whole display of brass, metal, and wooden defusers.
strategery 09-05-2012 10:59 PM
They didn't offer to sell new ones. They just recommended I replace my wooden ones with regular metal ones. They claim the wood ones restrict airflow.
beenthere 09-06-2012 05:46 AM
They are correct.
COLDIRON 09-06-2012 08:25 AM
I can see the wood product restricting some air flow it can't be that much more. Flow measurements would have to be taken to see the difference.
I would use whatever I liked that look good and matches the decor.
angelatc 09-06-2012 08:33 AM
IF you're the crafty type, you could use the metal type and paint a faux wood finish on them.
COLDIRON 09-06-2012 10:15 AM
Quote removed due to non related text......
beenthere 09-06-2012 05:28 PM
20% minimum reduction in air flow for the least resistive wood floor supplies. 40% on many of them.
A 4X10 metal often needs to be increased to a 4X14 wood to get the same air flow.
Daugela 08-09-2015 08:32 PM
I know this thread is super old, but I came across it during a search of my own issues involving an HVAC upgrade. I took off all of my custom wood floor registers and REALLY noticed a difference in the coolness of the house.
I'm not kidding!!
user_12345a 08-09-2015 08:37 PM
You can get plastic registers which look like wood and seem to flow air even better than the stamped metal ones.
http://www.floorregistersonline.com/...ta-01.jpgp.img
Daugela 08-09-2015 10:08 PM
Really?...I'm looking for galvanized ones to give an industrial look, but nobody sells them. How are the plastic ones better? Seems the thin metal slates at the most efficient. Out here in AZ, nobody sells the 6x10 since nobody has floor registers. Need to find online.
user_12345a 08-09-2015 10:12 PM
I don't know if they're better than stamped metal.
I assume that the stamped registers aren't the greatest - non-stamped metal would be ideal.
Technow 08-10-2015 02:44 PM
The big box stores sell brass restrictive floor vents and filtrete filters....and everyone calls the AC contractors theives....... :)
SPS-1 08-10-2015 04:44 PM
Doesn't seem make sense. Your AC will keep running until your house reaches the temperature on the thermostat. If you didn't change the setting on your thermostat, how can your house be cooler?
