Old 09-17-2012, 01:53 PM   #1
attic venting and insulation
Im about to purchase a home and I ahd an inspection done. i was advise that the attic temp was a 130 degrees and the air flow was different temp going to the addition of the house than the other part of the house could poor insulation be the problem or the attic not vented correctly and the ducts not right
thawk is offline   Reply With Quote
Old 09-17-2012, 06:20 PM   #2
An old Tradesmen
Attic not vented enough.
Old 09-17-2012, 08:55 PM   #3
Anyone use a solar attic fan?
bobelectric is offline   Reply With Quote
Old 09-17-2012, 09:08 PM   #4
Is there a ridge vent? Did it have soffit vents?
I personaly would not buy a solor fan. A ridge vent vents the whole roof not just a circle. Power vents leave hot moist air trapped in the rafter bays.
Ridge vents have no parts to fail, and work 24/7, no matter if the sun is shining or not.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-20-2011 12:31 AM
Venting and Insulation spaceboy Roofing 9 09-08-2011 11:29 AM
Attic Project – Venting and Insulation spaceboy Insulation 3 09-08-2011 10:54 AM
Attic insulation and soffit venting zacker Building & Construction 1 07-15-2010 11:17 PM
