Attic Vent Too Near Ridgeline? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-23-2012, 03:22 AM   #1
Attic vent too near ridgeline?
All attic vent instructions say to postion the vent as high as possible but with the highest part of the vent structure below the roof apex. Why is that? I may need to fudge that and I want to know what to look out for.
JLAMBERTI is offline   Reply With Quote
Old 06-23-2012, 06:34 AM   #2
Rewards Points: 14,306
Why are you not using a ridge vent instead? A ridge vent will vent the whole roof not just a big circle.
You need to mount any roof mounted vent far enough below the roof cap in order to be able to properly seal around the entire vent, not just the sides and bottom.
JLAMBERTI (06-23-2012)
Old 06-23-2012, 11:02 AM   #3
I should have been more clear. I'm installing a solar attic fan. I just set it up there now and the flashing doesn't come any where near the apex. (shallow pitched roof 3:12)
Old 06-23-2012, 11:55 AM   #4
Not a big fan of those.
There just never going to be able to pull enough air out and a lot of the hot moist air will still be stuck between the rafter bays.
Old 06-25-2012, 04:26 PM   #5
Rewards Points: 266
Power vents in attics are not always a good idea. Most of the time they are not a good idea, but it depends on your climate and the construction of your house.
See this for some information:
http://www.energyvanguard.com/blog-b...Are-a-Bad-Idea
ionized is offline   Reply With Quote
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
Snow in attic through turbine vent nymlake General DIY Discussions 1 12-18-2010 11:06 AM
Opinions/experience with Attic Breeze Solar Fan? matrixman Roofing/Siding 2 09-23-2010 11:59 AM
Installing gable vent from inside attic? RDS Roofing/Siding 0 03-12-2010 01:13 PM
is an attic vent required for cedar shingle roof? walenta Building & Construction 2 10-25-2007 10:31 AM
